I have three bugs to report since the 16.22 firmware update :
1. The USB connection between the Basecamp software and the watch no longer works. The message that appears is the following :
Un problème de connexion avec l’appareil Garmin s’est produit EPIX […] Veuillez contacter l’assistance client de Garmin pour obtenir de l’aide.
Consequence : waypoints, routes and tracks are no longer accessible, it is impossible to transfer new ones without using Garmin Connect or Garmin Explore. It's annoying because the possibilities are really limited.
2. The battery is plummeting between 15% and 20% per day …
3. An older problem, a display bug: when the temperature is displayed, the little circle which expresses the degrees is not in the right place, it is too low, it should be higher, in superscript. I'm nitpicking but before it was well displayed !
