I use heart rate zones for my running training. And I use % lactate threshold as my calculation.
This normally works well. I set my zones on my Epix 2 to be
Zone 1 = 75-79% of lactate threshold
Zone 2 = 80-89% etc etc
I had assumed that when my watch autodetects a new lactate threshold result then all my heart rate zones would simple ‘recalculate’. E.g. if it moved from 165 to 169 then the heart rate zones would stay the same as 75-79% and the beats per minute would adjust correspondingly. On my old Fenix 6 Solar I could have sworn that’s now it worked; that the % ranges would stay the same and the beats to minute change based on the lactate threshold number.
Having moved to the Epix 2 I’m finding that when the lactate threshold number changes, then the % ranges I’ve input change to hold the beats per minute at the same rate as before. So for example, when lactate threshold changes from 165 to 169 then the percentages of my zones would change to something like 71-76% and 77-85%. This makes no sense to me. If I’m selecting zones based on a specific % range, why is it that the %’s are changing.
Like I say, I don’t recall my Fenix 6 working this way. Am I missing something about how the zones are setup and calculated and adjusted when my lactate threshold is auto detected and changed.
Thanks all, this is slightly frustrating and leading me to question my watches zones for my zone training. Also can anyone confirm if the Fenix 6 works a different way. I no longer own it to check.
Thanks all.
