All is in the title: It seems like Time Sync (GPS and BT) is not working even if GPS fix is fast and reliable.
It draws the circle and then it stall and stall....
Do you got the same issue ?
I'm on 16.22.
I'm on 16.22.
In settings, 'System/Time/Set Time' - have you got it set to 'Auto' otherwise it won't sync.
I've always found that the watch doesn't sync exactly to the phone time, it's usually 3 or more seconds behind.
Edit: yes, I'm on 16.22 also.
Thank you so much.
Yes it was set to "Manual". Now it is back to "Auto" ! :-)
