Epix Gen 2 battery saver automatically turned on with when battery is under 40% with no warning and no sleep data it seems ? How can we disable this annoying feature after the last firmware or change to 20% or less ?
I had d this happeend to me an annother friend also.
We must  have a solution
Top Replies
  • Hello
    I am sorry to hear you are having this issue. First I would check to see what your battery save settings are currently:
    1. Hold the menu button
    2. Select Power Manager
    3. Select Battery Save
    4. Select…
All Replies
  • Hello
    4. Select Low Battery Alert
    5. Choose the desired time frame for this
    You will also want to check your Sleep Mode settings, if you notices this after sleeping:
    1. Hold the Menu button
    2. Select System
    3. Select Sleep Mode
    4. Ensure Battery Saver is disabled
    If there is no change, I would also recommend trying a hard reset on the watch. For this, hold the Light button until the watch shuts off, as opposed to selecting power off. Then power this on again.
  • Have mine set to 12hrs / 1hr gps + music. I assume this is around 10% as GPS+music is estimated around 10hs. Though as general use is between 14-16 days i.e. 6-8% per day it would suggest going on general use of 12hrs that means 3-4%. Happy if mine triggers around 10%.
    Using this I have never seen it trigger yet and have got as low at 20% befere.
    If yours is set to the minimum amounts and you still occassionally get this issue, note that there is a sleep profile bug in that if your battery saver is set to on during sleep profile, sometimes when the watch switches off sleep profile it doesn't actually switch off battery saver; sometimes its DND (again if set to sleep schedule). Its random and experience this occasionally about once a month. Just go into control menu and turn off battery saver / DND as required. And maybe you are experiencing this bug rather than a battery saver setting (check your low battery alert setting).
