I have an issue with the data fields on one of my watch faces: only the bottom two fields function when pressed. It's a stock Tactix watch face. Does anyone have a solution for this minor issue?
Thanks!
Thanks!
If you change to another default stock watch face, are you then able to long hold and go into the glances for the "same data fields" that are not working on your watch face shown in your picture?
Exact same thing on my T7 AMOLED and only on this watch face. The only difference is that one or two fields work by long press and then all of them stop working. All other watch faces are working fine.
Yes, every other face works fine. It’s a minor bug, but I prefer this watch face!
Yes, exact the same behaviour. Hopefully it’ll get a big fix soon.
Thank you for the update. Please post a picture of the watch face that is not responding correctly. I can then replicate the issue on our end. I will be happy to write a new case to be escalated to our engineering team to have the new issue resolved. Thank you in advance. We appreciate it.
