I have new epix pro (42mm). As shown in specifics, trail running activity should be in the menu. But it is not. How can I add it?
Thank you for your help :-)
Katja
Katja
I have an Epix Pro and it has trail run. Try this - press start, select Add, then select Running and Trail Run should be an option to select
Thank you. But I don't have this option. I have checked several times, turned off the watch but still nothing :/
This should be available from the watch, Garmin Connect Mobile (GCM) or Garmin Express. On the watch you get to it as indicated above . From the bottom of the activities list you have you'll see a + Add option. Select that and you'll see folders with the available apps. Please list the activities you have in the Running folder of the activities list on the watch?
From GCM, find you device. Go to Settings, Activities & Apps. Select Add at the bottom of the list then scroll through until you find Trail Run. If you're doing this in GCM (iOS at least) it looks like the activities are not grouped like they are on the watch. There's a huge list of activities to scroll through so quite possible to miss.
The last option is to try syncing with Garmin Express then look in Garmin Express for it and add it there.
If it's still not there then you might need to clear all data and reset.
Your new watch shows to be on older software. Please update to the most recently released v14.36 software. Although odd you do not see Trail Running as an activity profile APP to add to your watch's favorites, you should be good to go after you have fully updated your software.
If you want to download the update to your watch the quickest, use Garmin Express on a computer.
