Bad performance (CPU / FPS) on Epix Pro
I switched from the Fenix 7x to the Epix 2 Pro. I found that the Fenix is much better performing than the Epix Pro.
Incoming notifications are displayed on the Epix at only about 10-15 fps. Everything jerks and is anything but fluid. Frame drops also occur when quickly scrolling through or reading notifications. Activating the torch by double-clicking on the Epix also takes much longer than on the Fenix. On the Fenix, the flashlight comes on immediately after the second click, whereas on the Epix, the flashlight only lights up when the hand is long gone.
I am aware that a higher clock speed of the CPU causes higher battery consumption. But I'm really unhappy with the Epix Pro right now because of the jerky behaviour. I wish Garmin could add an option under power settings to increase CPU at the expense of battery. I would be too happy to trade 1 week of runtime for good performance! Currently I absolutely regret of buying the epix instead of the fenix as I cant send it back (bought at reseller)
P.S: A standard dial has always been used.
  • I find my Epix quite responsive (non pro), but primary uses buttons. Using touch to scroll through glances is bit jerky and and panning on the map also is a bit slow to update. But for my normal use, I have no complain. I have 955 also and haven't noticed any speed deficit except panning the map due to higher resolution and pixels to draw.
  • It's having the same CPU (and if you can call it so GPU) as the 7 but 4 times the pixels. I don't think there will be a fix. Its
    a lag of computing power.
  • Bei mir geht die Taschenlampe sofort nach dem Doppelklick an. (Epix 2 pro 51 mm
  • I noticed it as well, and that was the primary reason I returned mine. I bought mine at launch and sort of assumed they'd have fixed that by now. I really noticed it on inbound notifications.
  • I received mine today as well and I can see the lag. Especially on the 51mm which has more pixels to push to the screen. Garmin should give us an option, as suggested, to prioritize performance over battery so we can have consistent framerate and the experience is fluid. WearOS used to be horrific in terms of dropped frames and Google fixed it, it wasn't an issue on my Fenix 6 also. I mean make it a user choice, especially on the 51mm, the battery life demolish the competition so I don't care of losing a day or two just so that I enjoy using my watch, and scrolling doesn't feel like the first gen Nokia/Blackberry touchscreen phones.I work on the tech industry and these days there is really not much customers that agree with sluggish UIs delivered to them.
  • It's especially bad on the widgets glance if you use the touchscreen to scroll.
  • Hi,
    Fenix 7 / Epix 2 standard and F7/E2 Pro have the same "CPU" component.
    https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/318547/garmin---benchmark---fenix-6-series-and-f7-e2-comparison-positioning
    At the launch of the standard Series, i saw CPU score of 9.4, but since many months reports provide 7.8 at max, i can't explain why.
    But Venu 2 Plus, FR945LTE and FRx55/FRx65 seems to always provide this higher score.
    I will request for new reports from FR users with latest System version ASAP.
    Can you run the 2 benchmark app and give your feedback here ?
    I recommend to use the latest Beta to reflect the next Public release - https://forums.garmin.com/beta-program/fenix-7-series/f/announcements
  • But i don't saw nothing clearly relevant to performance in the Beta changelog.
    Some lock/laggy/drawing that could help/improve it ???
    Version Models Description
    14.31 All Fixed issue with connection to PC for GameOn support on Marq 2 devices.
    14.31 All Fixed issue in workout app where incorrect icons could be shown.
    14.31 All Fixed potential lockup on the wallet page.
    14.30 All Improve messaging of pending CIQ items during a device restore.
    14.30 All Improve Red Shift handling for "After Sunset."
    14.30 All Improve Workouts app to not be available when an activity is already recording.
    14.30 All Update auto lap page layout when displayed during a workout.
    14.30 All Updated translations.
    14.30 All Fix possible shutdown when using weather radar.
    14.30 All Fixed issue causing missing Morning Report pages on Race Day.
    14.30 All Fixed issue with the weather app needing to be launched after an update or power cycle before it was getting new data.
    14.30 All Fixed issues with watch face calendar data field.
    14.30 All Fixed possible empty page in Tides widget.
    14.30 All Fixed possible issue when creating a custom multisport activity.
    14.30 All Fixed possible issue where dashed average line would not draw correctly on some charts.
    14.30 All Fixed possible issue with altimeter after a swimming activity.
    14.30 All Fixed possible recurring crash that could occur if wireless software fails to update.
    14.30 All Fixed possible shutdown after saving an activity.
    14.30 All Fixed potential issue where InReach messages were not showing up or updating on the device.
    14.30 All Fixed potential shutdown when scrolling through Glances.
    14.30 All Fixed potential UI issue on Stress graphs.
    14.30 All Fixed shutdown when using workouts app with no workouts available on the device.
    14.30 All Fixed snorkeling incorrectly recording elevation.
    14.30 All Fixed stress chart possibly being empty in a gaming activity.
    14.27 All Add CIQ App Rating to all CIQ Types (no longer restricted to "Apps" only).
    14.27 All Add checkmark on the start key to the backup found page.
    14.27 All Add missing settings and data field options to Horseback activity.
    14.27 All Improved workouts app to be less laggy.
    14.27 All Improve backlight to not unexpectedly enable in many scenarios.
    14.27 All Fixed possible missing weather conditions on morning report greeting page.
    14.27 All Fixed issue where weather radar could stop drawing data.
    14.27 All Fixed possible issue where morning report opened the wrong race on race day.
    14.27 All Fixed issue in fish forecast where time format preference would not be respected.
    14.27 All Fixed possible issue where "Touch Disabled" banner in swimming activities would draw on top of menus.
    14.27 All Fixed possible issue where palm-to-close would not work.
    14.27 All Fixed possible shutdown when saving an activity.
    14.27 All Fixed issue where golf driver distance picker would use the wrong units.
    14.27 All Fixed issue where Spotify player would appear blank.
    14.27 All Fixed issue where connecting headphones causes playlist to restart.
    14.27 All Fixed issue where line would draw incorrect in big numbers mode for Golf.
    14.27 All Fixed issue where respiration data field would not work in an archery activity.
    14.27 All Fixed possible shutdown when using a Varia RCT715.
    14.27 All Fixed possible issue where workouts could not be deleted when accessed through the workouts app.
    14.27 All Fixed possible shutdown when opening the Workouts app.
    14.26 All Added a link to Garmin Connect Mobile in My Workouts within the Workouts App.
    14.26 Marq2 Added a new Marq 2 watch face.
    14.26 All Added haptic feedback to wifi sync failure case.
    14.26 All Added touch disable back to the swim app.
    14.26 All Improved My Workouts list in the Workouts App.
    14.26 All Workouts app now sorts by sync time.
    14.26 All Fixed drawing issue with chart data fields in certain data field positions.
    14.26 All Fixed incorrect line drawing in expedition mode.
    14.26 All Fixed issue causing stale weather data.
    14.26 All Fixed issue where some activities were incorrectly showing up in the workouts list - this will only affect new activities going forward.
    14.26 All Fixed issue where the blue "read" indication dot in the workouts app was not clearing when a workout is Scheduled.
    14.26 All Fixed issue with e-bike range data field.
    14.26 All Fixed issue with Gaming win rate not matching Garmin Connect.
    14.26 All Fixed issue with sleep watch face showing an incorrect alarm time.
    14.26 All Fixed issue with workout icons having inconsistent colors.
    14.26 All Fixed potential empty item when adding a new data page.
    14.26 All Fixed potential shutdown in the Workouts App.
    14.26 All Fixed shutdown when viewing workouts app with 0 custom workouts.
    14.26 All Fixed watch face data field overlap issue introduced in 14.24.
    14.24 Marq2 Added new watch faces to Marq 2 (Note: you will need to go to Add New and browse layout options to see these)
    14.24 All Added power guide support to the race widget.
    14.24 Marq2 Added tree drawing to golf on Marq 2.
    14.24 All Updated pace alert UI.
    14.24 All Fixed issue with touchscreen not working when the backlight is off on fenix 7 series devices.
    14.24 All Fixed issue causing heart rate data to not download after a swim.
    14.24 All Fixed issue that could cause stale weather data.
    14.24 All Fixed issue with golf Plays Like using stale weather data.
    14.24 All Fixed potential display flicker when using Connect IQ watch faces.
    14.24 All Fixed potential shutdown on weather map.
    14.24 All Fixed potential UI issue with the start of chart data field drawing.
    14.24 All Fixed UI flow issue after deleting a workout.
    14.24 All Fixed UI issue with menu items when creating a custom multi-sport activity.
    14.23 non-Pro Added new activity types to non-Pro models: American Football, Field Hockey, Ice Hockey, Soccer/Football, Lacrosse, Rugby, Ultimate Disc, Cricket, Softball, Archery, Overland, BMX, Racket sports and more!
    14.23 All Added Device Settings Backup and Restore.
    14.23 All Added ability to set multiple locations in the weather app on device.
    14.23 All Added Gaming App.
    14.23 All Added Workouts App.
    14.23 All Added Fish Forecast widget glance.
    14.23 All Added Golf "Plays Like" improvements.
    14.23 Amoled Added Golf Biomes support for OLED products.
    14.23 All Added Multisport option for race calendar.
    14.23 All Added new Golf Virtual Caddie interface.
    14.23 non-Pro Added Shaded Relief feature to the map for fenix 7 series, Epix Gen 2, Marq 2, Tactix 7.
    14.23 non-Pro Added split screen and radial data field layouts to the map for fenix 7 series, Epix Gen 2, Marq 2, Tactix 7.
    14.23 All Added support for new Di2 cassette sprocket patterns.
    14.23 non-Pro Added support for the Recent Apps hot key to Non-Pro models.
    14.23 non-Pro Added support for weather overlay map in the weather app for fenix 7 series, Epix Gen 2, Marq 2, Tactix 7.
    14.23 Marq2 Added Virtual Caddie suggestion in green view for Marq 2.
    14.23 All Added workout muscle map support for HIIT, Cardio, and Pilates.
    14.23 non-Pro Amoled Enable Red Shift on non-Pro AMOLED products.
    14.23 All Improved golf Hole Picker.
    14.23 All Improved golf Virtual Caddie feature.
    14.23 All Fix Golf scorecard button not properly dismissing.
    14.23 All Fix race time prediction on races with distance longer than a marathon.
    14.23 All Fixed Connect IQ watch faces still getting gestures even when gestures are disabled.
    14.23 All Fixed issue when paired to Varia Vision.
    14.23 All Fixed issue with Race Day weather wind speeds.
    14.23 All Fixed potential issue causing the inReach widget glance to stop updating.
    14.23 All Fixed potential issue that could cause a crash on software update.
    14.23 All Fixed potential issue when a large number of mp3 files are on the device.
    14.23 All Fixed potential issue where a user may be unable to play music in Spotify.
    14.23 All Fixed potential issue where Spotify would show blank except for the control buttons.
    14.23 All Fixed potential issue with the Reference Point App when a large number of waypoints are loaded.
    14.23 All Fixed potential shutdown in the Tides app.
    14.23 All Fixed potential shutdown in Tides option menu.
    14.23 All Fixed potential shutdown when using a course and viewing the Climb Pro data screen.
    14.23 All Fixed potential UI issue with HRV display in Morning Report.
    14.23 All Fixed UI flow issue when viewing an event in the calendar.
    14.23 All Fixed UI issue when a 3 digit HRV value is present in Morning Report.
  • Here my result (epix 2 pro 51mm v 14.31):
    Cpu 7.6 / 55.6 pips
    I don't really notice any lag. on the other hand between my old F6pro and the epix 2 pro it is much more fluid ...
    Edit : I run a another benchmark : CPU 7.8/ 58.8 Pips....
    There is a little fluctuate with the results...
  • Can you run the 2 benchmark app and give your feedback here ?
    Hi,
    mainly the issue exists during incoming notifications. Here are the results:
    Connect IQ Benchmark:
    SW 14.31 | 454 x 454
    Connect IQ 4.2.3
    CPU 7.8/ 58.8 Pips
    3D Benchmark:
    This App is not compatible with EPIX PRO 51 mm
