On my Epix 2 I don't get VO2 Max measurements when indoor rowing. I use a heart monitor which connects perfectly.
Is there a setting that I should alter?
Thank you!
Thank you!
VO2max can be calculated a couple of ways: https://support.garmin.com/en-GB/?faq=lWqSVlq3w76z5WoihLy5f8 with running one being the primary, cycling with a power meter being secondary, then it would be a…
From the manual:
You must run either outside with GPS or ride with a compatible power meter at a moderate level of intensity for several minutes to get an accurate VO2 max. estimate.
So indoor running…
I may be wrong, but I thought VO2 max can only be calculated with running or bike?
VO2max can be calculated a couple of ways: https://support.garmin.com/en-GB/?faq=lWqSVlq3w76z5WoihLy5f8 with running one being the primary, cycling with a power meter being secondary, then it would be a walking VO2max, the final option being based off your all day HR - however with this method can take up to 30 days to provide a VO2max.
From the manual:
So indoor running doesn't support VO2max calculation.
