Always on works, but watch and metrics freezes when dimmed?
AOD on and wrist gesture on.
However, there appears to be an issue with all Garmin watch faces (not using third party) when the watch times out in always-on mode. When the watch times out and dims, the time and sensor metrics, such as heart rate, stops and freezes. This defeats the purpose of having an always-on feature if I cannot readily view the time or metrics when the screen is dimmed. Is this behaviour a known bug or is it intended?
Additionally, it's quite annoying that when I flick my wrist to check the time, I notice a glitch on the watch face where the time jumps from the frozen state to the current time when the watch turns from dim to bright. I'm curious if this is a common occurrence experienced by all users.
I have tried resetting the garmin watch - but doing so my watch is now saying no sleep data recorded, even though my connected phone shows my past sleep metrics. All other metrics has updated and synced to watch from phone after the reset, should sleep metrics sync over and synchronise from phone to watch too?
Software version 13.22
  • When the watch goes into standby mode (dim screen) the time and metrics shouldn't completely freeze - it just reduces the refresh rate to once per minute to preserve battery life. That's the normal and intended behavior, it works that same way even on the MIP/transflective display watches. Can you verify that's what's happening? Or is your time/data staying totally frozen for longer than 1 minute? (because if that's happening, then no that's not normal)
