Epix pro 51mm - Open water swimming - altimeter shows -40m afterwards and needs to be corrected manually
After swimming the altimeter of the Epix pro 51mm showed -42m
and didn’t go back - even with automatic altimeter correction.
so I need to manually correct it! That’s what I diD, you can see it in the graph.
(did this test more than one time, always the same problem)
so also the barometer arrows are totally wrong afterwards.
never had this problem with my Fenix 7x
