maybe I'm missing something but I cannot find the red shift mode in the new Epix Pro.
I looked in the appearance settings for the controls but cannot find it.
Any input would be great
Has anyone turned on the After Sunset option for Red Shift mode? It seems like it turns on reasonably close to sunset, but never actually turns Red Shift mode off when the sun rises in the morning (which…
Guys, just got Epix Pro, updated software to 13.22*, but I do not see Red Shift neither in Display settings nor in Controls.
Anyone else on 13.22* not seeing Red Shift ?
Thanks but that the problem, its not there. I looked in the appearance settings to try to add it. Still not there.
Just curious if anyone else has it missing
I did not and wasn't familiar with adding to the Control Menu. Thank you!
I can't see Red Shift with 13.22 firm too.
Do you see version number with an asterisk in the end ? Like 13.22* ? Also, when you open Garmin Express what version number is displayed there for your Epix Pro ? My says 12.74 and does not find any newer
Mine just updated to 12.74, I can't get it to 13.22 either.
Hello everyone, I have the same situation: I have 13.22* but Garmin Connect shows 12.74. No redshift, weather overlays etc. available
Ok, so there are multiple cases already where Epix Pro stuck on 12.74 and does not update to 13.22. Software update function does not even find 13.22 as an available update.
Can somebody from Garmin team please explain why some Epix Pro users are not getting 13.22 which suppose to be generally available ?
Same. Updated 13.22. I've been trying to get red shift mode to work since release. No luck yet. Glad to see I'm finding others with the same issue
Are you really on version 13.22 ? Does it display “*” in the end? Like “13.22*” ? If you open Garmin Express what version number is displayed there ? 12.74 ?
13.22 for Epix2 PRO:
You can try to upload and install the file manually.
