Hello, this morning the touch screen of my epix 2 does not respond well.. if I touch it it does not respond to touch. I restarted the watch but the problem persists. The SW version is 11.25, have you also had this problem? it's pretty annoying.
Are you absolutely sure you haven't deactivated the touch screen somehow? There's a Touch option in the controls menu, check if it's enabled?
www8.garmin.com/.../GUID-700E76C4-F7E2-4984-8199-D59D6A31DFB9.html
Also default is press and hold top right and bottom left buttons together to enable/disable touch.
