Is it possible to setup one of the buttons on the back watch as hot key for timer ..
yes but only a couple of the buttons work on long press, however you also have button combo options.
Personally I have set mine to take me to timers using menu + start (left middle + top right).
You can't do to a specific timer, only to the timer app - but actually prefer that as you can quickly and easily see a list of all timers and which ones are active and where they are in the countdown.
How do I do that . Using Garmin connect app ?
open connect app and making sure that your watch is connected to your phone, press on your watch icon in the connect app.
scroll all the way down to system and press on system.
scroll to and press on hot keys
select the hot key combo you want to use - and it will open a list. Select the hot key function you want to use.
You can also do it on the watch itself:
Long Press the middle button to access settings> System> Hotkeys
