Hello everybody,
after the last update (ver. 10.43), it often happens that the autolap voice instead of saying the number says the name of the month, for example "Lap 1 1:20" is said "Lap one January 20". My Epix is in Italian so it says "Lap uno gennaio 20". Does this happen to anyone else too?
I want to add that I use bluetooth headphones connected to a smartphone that is connected to the watch. In this case the problem occurs. However, if I connect the headphones directly to the watch, the problem does not occur.
It is as if the smartphone interprets the message sent by the watch considering it as DATA. Perhaps there is a bug in the data format provided by the watch to the smartphone
If I press the lap button before the minute, for example at 00:55, the voice message is correct "Lap one zero fifty five" so I imagine that both the concatenation of the 3 numbers representing a valid date are interpreted incorrectly by the smartphone because at the otherwise the month 00 does not exist and everything works. Maybe it's the format in which the watch sends data to the smartphone? "Lap 1/00/55" is fine but not "Lap 1/01/20"?
