What is the best way to report a bug?
How does one report a bug in the watch firmware? I can't find any links to bug reporting on the Garmin website. Mentioning the bug in this forum seems to have no effect (e.g., Race an Activity has had bugs for years across the Fenix range at least, and no progress has been made). The beta forum appears to have bug reporting, but this isn't a beta firmware issue and I don't want to download beta software to report a longstanding bug.
  • The best way is to contact Garmin Support. They will analyze your input, identify if this is a bug or not, whether it is known or not and take the necessary actions (help you understand, resolve or create a ticket).
    In rate occasions will a post in these forums lead to some action by engineering. This happens when a Garmin moderator intervenes in the discussion and discloses whether further investigation is taken on.
    The more customers end up added to the same ticket, the higher chances the ticket will be prioritized in the engineering queue, whether serendipitously  through Garmin support, or pro-actively through select forum posts.
  • Thank you, but how does one contact Garmin Support? I looked at the Garmin website, and the only remotely relevant thing I can find is a form to make a suggestion for improving a product, which is sent to the "innovation experts". This doesn't sound like a good place to report a bug.
  • how does one contact Garmin Support?
    epixTm (Gen 2) | Garmin Customer Support, then at the bottom of the page, chat, call, or email.
  • Interesting, thank you! On the Australian version of the site, the EMAIL option is missing.
  • And today when I visit the link posted by seilogramp above, I don't see any options for contacting Garmin!
  • Thanks for taking the time to reply. With more exploring I have seen a variety of behavior on both the Australian and US sites. Sometimes I don't see any additional instructions for how to contact Garmin, sometimes only CHAT and CALL are shown, with the EMAIL option missing. Anyway, during one attempt when EMAIL was visible, I managed to send a bug report.
  • You could also send an email directly to [email protected]. I've used that address in the past and gotten support from them.
  • I have seen a variety of behavior
    Options come and go based on operating hours and when each form of support is available. It is normal behavior.
  • Hi Chris,
    Just following up on this. I haven't had any luck interacting with Garmin to report the "race an activity" bug.
    Here is the confirmation from Garmin of my original bug report:
    Date: Sat, 26 Nov 2022 15:27:36 -0600
    Subject: Confirmation of email submission
    Reply-To: Garmin <[email protected]>
    _______________________________________________________________________
    Subject: Race an Activity has long-standing bugs affecting multiple
    users for years
    Problem Description Race an Activity has bugs (on Epix-2, Fenix-5 & 6,
    and Instinct, at least) that have been reported on the Garmin user
    forums for as long as 5 years without resolution, e.g., see the
    representative sample below:
    forums.garmin.com/.../epix-
    2/308935/issue---race-an-activity
    forums.garmin.com/.../fenix
    -6-series/274926/race-an-activity-not-displaying-correctly---19-2
    -5-series/239355/how-to-race-an-activity-hint-don-t-race-an-activity
    -6-series/271474/old-bug-time-ahead-behind-when-racing-an-activity-and-
    solution
    -5-series/192082/race-an-activity
    forums.garmin.com/.../insti
    nct/165604/race-past-activity-not-working The main issue is that the
    "time ahead/behind" field can show completely nonsense values
    throughout the race, e.g., over an hour behind when the activity is
    only 45 minutes in length. At the completion of the run, the watch
    reports the correct values. The behaviour seems to be semi-random,
    e.g., I have done several run racing against the following activity:
    [redacted] and the first few
    of them worked fine, but then it started to show values of time
    ahead/behind of over an hour at the beginning of the run. Since this
    behaviour started, I have seen it every time when racing against this
    particular activity, and with the same initial offset. Another bug with
    Race an Activity is that the calculation for the estimated time to
    completion is very poor, e.g., on one 45 minute run that I do, the
    estimated time to completion jumps up and down by a minute even when I
    am only 50 metres from the finish. There is clearly something very
    wrong with the code that does this calculation.
    A couple of days later I received an email from Garmin to participate in a survey to rate their feedback (which was zero, apart from the email above):
    Date: Mon, 28 Nov 2022 09:30:43 -0600
    Subject: Rate your Garmin Support Interaction
    Please help us by rating your recent interaction with our Product
    Support Team.
    Your participation is completely voluntary. Your feedback will be
    treated confidentially and only used to improve our Product Support.
    Rate My Interaction
    Sincerely,
    Garmin's Product Support Team
    I tried email a few days later:
    Date: Sat, 3 Dec 2022 16:17:55 +1100
    But this bounced with:
    Your message couldn't be delivered because there is a partner connector
    configured that matched the message's recipient domain. The connector
    had either the RestrictDomainsToIPAddresses or
    RestrictDomainsToCertificate set.
    I also tried another email address:
    Date: Sat, 3 Dec 2022 16:24:01 +1100
    To: "[email protected]" <[email protected]>
    Subject: Re: Rate your Garmin Support Interaction
    but received no reply.
    This is really a pretty poor situation. The bug I am trying to report has been a major issue across the FENIX line (and EPIX 2) for many many years. "Race an activity" is a very useful feature that doesn't work correctly. The bug has been repeatedly reported by users on the forums for years, but nothing happens.
    Is there any way forward? I am just trying to help Garmin improve its firmware, and have put a fair bit of effort into this, and have made no progress.
