I’m going to be taking a small diving trip and can’t see to find a diving activity on my epix. Any ideas what to use instead? I don’t really see a relevant activity
From the Owner's Manual:
Swimming
NOTICE
The device is intended for surface swimming. Scuba diving with the device may damage the product and will void the warranty.
NOTE: The watch has wrist-based…
If you want to take the risk of the water damage voiding the warranty, use for example Open Water Swimming, and then change…
its not just $5 on the seals - it is also changing the button design to inductive buttons etc.
But yes tend to agree with you that it would be nice if these watches were rated to that level as long as…
Swimming
NOTICE
NOTE: The watch has wrist-based heart rate enabled for swim activities. The watch is also compatible with the HRM-Pro , HRM-Swim
, and HRM-Tri
accessories. If both wrist-based heart rate and chest heart rate data are available, your watch uses the chest heart rate data.
To clarify, I’ll be 20-30 feet under the water. The watch is waterproof and should be able to handle that.
because
And well it might but Garmin suggest you don't dive with it. It's up to you.
It's up to you. If your watch dies, you'll have to buy a new one.
If you want to take the risk of the water damage voiding the warranty, use for example Open Water Swimming, and then change it to one of the Scuba Diving types, or to Apnea (if freediving), in Garmin Connect. That's what I do when diving or freediving with my Instinct 2.
Avoid pressing the buttons when underwater.
Without continuing the conversation of whether the watch can or cannot work while diving, I’ll give you my personal thoughts.
During the dive, the watch will not give you any useful information other than time, and since it can’t be used as a dive computer you will (should) already have a separate dive computer or other devices to track depth, time, NDL time remaining, etc. Therefore, I take my Epix off and leave it on the boat.
I do, however, use the Boat activity on the Epix to track the dive start location and pick up location, and then I use the Garmin Dive app to manually record the details of the dive from my dive computer plus the entry and exit point I recorded on the Epix. Using the Garmin Dive app puts the activity in Garmin Connect as well.
I am considering getting a Descent G1 to use while diving, but I haven’t pulled the trigger yet.
I do not understand why Garmin cannot just add $5 to improve the seals and allow Fenix / EPIX / Tactix / Enduro owners to do recreational diving a few times per year. Isn't this supposed to be a top-of-line-rugged-outdoors-track-every-activity-watch? Even the relatively toylike Apple Ultra has this capability (despite also having 3 microphones plus an 86dB speaker). Imagine the advertisement where dude removes his $2500 Marq 2 Captain (a friggen tool watch built for the SEA!) for a 60 foot dive in Bermuda, replacing it with an AWU!?! Or a Navy seal operator rendezvous with submarine by parachute "standby team. I have to remove my Tactix 7 because Garmin will void the warranty"
Well, that is definitely true right there.
But yes tend to agree with you that it would be nice if these watches were rated to that level as long as it doesn't buik out the case/weight by more.
I wore my Epix Gen 2 on a recent dive trip. I did eleven dives with a maximum depth of 90 feet and pressed buttons under water. Watch works fine. Data isn’t useful or interesting. Really only shows time and distance using the open water training option.
my two cents. Your watch will be fine, but content isn’t worth the risk
