Alpha v10.37 released
Alpha vers. 10.37 just released:
https://forums.garmin.com/beta-program/fenix-7-series/f/announcements/312344/alpha-version-10-37
As always - this is ALPHA software. So don't try it if you don't wat to risk it ;-)
Changelog
Added a prompt to end Resume Later for an activity when user is near their sleep window.
Added ability to add, remove, reorder Morning Report items.
Added background to Morning Report data pages.
Added Calendar and Step goal to Morning Report.
Added alerts for running power.
Added System Settings App.
Added hot key and power controls access for Settings app.
Added power chart data field.
Added power chart to post activity summary.
Added QR code to bluetooth pairing flow.
Added run power data fields for average watts/kg and lap watts/kg.
Fixed an issue causing Morning Report to show up at incorrect times.
Fixed issue causing confusion between daily suggested workouts and primary races.
Fixed issue causing incorrect What's New strings.
Fixed issue causing storm alerts to improperly show up.
Fixed issue with activity history list when large number of activities present.
Fixed issue with Connect IQ Swim data fields.
Fixed issue with Tides app not reflecting system time setting.
Fixed issues where maps were loading more than necessary.
Fixed issues with QR code pairing flow and pairing flow in general.
Fixed potential issue in Daily Suggested Workouts when changing target type.
Fixed potential issue with power zone graph drawing.
Fixed potential issue with run power data field subcategories.
Fixed some graphics drawing issues.
Fixed UI issues with Training Readiness and Intensity Minutes in Morning Report.
Fixes and Improvements to Morning Report.
Fixed issue causing increased battery drain after disconnect from a charger.
Fixed potential issue where Always On display would turn off.
Improvements and fixes for running power.
