Screen keeps turning on while in sleep mode.
This started to happen in 9.33 and has persisted in 9.36.
When my watch goes into scheduled sleep mode, I have it set to turn the screen off and go into low power mode with touch turned off, which it does.
But then throughout the night, the screen will come on. It seems to be gesture activated as it most often happens when I move my arm but its very sporadic. It doesnt happen every time I move my arm, and it also comes on sometimes while my arm is motionless.
Restarts of the watch do not fix it, nor has updating to 9.36.
Does anyone else have this issue? Its driving me nuts and is preventing me from wearing it while sleeping.
  • I have it set to turn the screen off and go into low power mode with touch turned off, which it does.
    I don't understand this.
    What are your settings under
    System > Sleep mode
    and
    System > Do not disturb
    and
    Power Manager > Battery Saver > Edit
    Did you try a soft reset? Keep the light button pressed on, keep it on as you see the emergency alert show up, until the watch turns off.
