Map download stuck at 95%
Hi,
I'm using Epix with SW 8.21.
When I'm trying to download Course View from Map Manager download is stuck at 95%.
I found similar bug in beta program but without answer.
What can I do ?
Top Replies
All Replies
  • same problem here.
    But found this solution in other post:
    forums.garmin.com/.../1427378
    "I figured this out from reading another user's posting.  You should go into map manager on your watch and delete the queued and partially downloaded maps until the status of of the maps simply states "Update Available".  At that point go into TopoActive maps and pretend to download a region.  When you do this MapManager synchronizes it's revision information with the server and when you return to previous menu there the "Update Available" status will be gone.  I tried this yesterday and it worked.  It seems MapManager does not properly synch with the server until you manually go in there to download a region."
