Hi ,
There have the problem when navigation , the watch is stuck and freeze when "calculating" map. This happened when select the routing and "Use Map"
Anyone facing this problem?
Thank you
Hi ,
Thank you
Hi,
I can't actually help solving the problem, but you are not alone ;)
I do have exactly the same problem (see forums.garmin.com/apps-software/mobile-apps-web/f/garmin-connect-web/294366/navigation-problem-when-using-map)
I confirm exactly same issue on last official firmware.
I also have the same problem. Still no fix to this?!
