Training load focus not lacking all "high aerobic" training, but I get low aerobic or anaerobic scores?
have couple weeks been using Epix 2 and I don't get any "high aerobic" numbers to the training load focus, regardless of the training I do instead. Instead they are either low aerobic or then if speed up, it gives instantly anaerobic points, even if my heart rate has been much of the training in high aerobic zone.. 14 days ago everything was fine and suddenly after upgrading the sw to edge 530 or Epix this problem occurred.  I still do the same exercises and there used to be no problem with anything.  Forum about Fenix 6 I found someone with a similar problem below:
7567310 in reply to
Hi Gilbert Jakub and all others with the same issue,
in the meantime on my side the issue is solved because of the Firmware upgrade of the Edge1030Plus from version 5.20 to 6.10.
So it has clearly nothing to do with any strap used. It was a major FW bug in the 5.20 SW of the Edge1030Plus.
The first ride I did after the upgrade of E1030Plus to 6.10 had Exercise Load of 195. This caused a jump from 0 to 185 on my High Aerobic training Load. The Low Aerobic and Anaerobic remained unchanged, so 10 points of Exercise Load are 'lost in space'.
1 week earlier, on FW version 5.20, I did almost exactly the same ride (both done indoor so very comparable) which upped Low Aer with 168 points and that was it. High Aer and Anaer remained the same where the start situation before the rides was also the same: 7-Day training load zero before both rides.
I suspect that maybe the basic FW version used for the 5.20 version was derived from FW versions earlier used for other devices which have had the same issue in the past as I found reported about elsewhere in this forum (mostly under a particular Garmin device like the Forerunner or Edge type).
Hope that Garmin will test future FW versions for devices much better than this one because now the whole Training Load Focus during the live period of 5.20, from 23-July until at least 15-Nov, is totally useless.
Also let's hope they never use the x.20 version again as root version because then it may be that the bug returns.
Epix has latest fw And my edge 530 has 9.40 FW ....aby solution ? Thanks
