Does or has anyone ran or walked or hiked an area with both single band (steel version) vs multi band? Just want to see the accuracy difference on a map. Super curious.
I did run comparison in forest month ago and I can say that difference is hardly visible. Both modes give very good results. Multiband only slightly better. For me no reason to enable. It might be more useful in big buildings, city, I don't know, but in forest regular more is so good that I can't image better results;)
Instant Pace for VO2Max / Performance status is less unrealistic if you run under trees / in urban canyons.
Otherwise, the multiband mode seems to go totally crazy from time to time, there's a thread about it here
You'll only see a difference in difficult areas. Definitely better in wooded areas or in tree lined roads.
https://quantified-self.io/user/EKZSTLHcIvbVEr6i6guJeX8LtWb2/event/vD9ueSedCf37N7Hk5PFv Multiband vs All system
https://quantified-self.io/user/EKZSTLHcIvbVEr6i6guJeX8LtWb2/event/79e4f8d42ccd80fb437776a857832ec91216290f3b3144f6fafe4860bf8a3448 Just another run with Multiband but no comparison
Judge by yourself but, personally, i find the multiband more accurate. I have to do other tests in more complicated areas.
If you're interested you can take a look here https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/epix-2/289260/epix-2-vs-forerunner-745-fenix-6x-pro-multiband-all-systems-gps-comparison where i did some tests also with other models and while the track looks really bad for older devices, the difference in total distance is negligible. I'll post other tests in future.
I do not know if this is visible or not but here is a hike through slot canyons. For the first third I had all satellites and you can see where the watch struggled a bit. I turned on multi band about 1/3 of the way through as I had forgotten about it. The track is quite clean in the second slot canyon. Slot canyon run
You need to change the privacy of the activity.
Thx for the info
