Battery life for epix 2.
What sort of battery life are people seeing. I was seeing 6 days with circa approx 4 hours of activities but now seem closer to 4 days.
  • Mine is going every bit of 2 weeks. Screen is set to wake to  touch screen only. Have been doing very little activities lately. Maybe your display and GPS settings are chewing up your battery.
  • You probably have pulse ox on. It drains battery. Better to turn it off. It's not usefull for normal situations anyway.
  • It is difficult for me to give any exact numbers since I don't really care, I charge when there is time and the battery won't last 24h including an activity. But his is what I know:
    • Last charge was 16th of March at 18:16 CET which is 6 days and 13 hours ago. Not sure it reached 100% but at least above 90%.
    • It is currently at 21%.
    • 4 running activities with HRM Pro (Jacket Mode) and Stryd (+Stryd datafield) totally 3h 48m 55s
    • 1 running activity with OHR and Stryd (+Stryd datafield) 51m 29s
    • 1 bike activity with HRM Pro (Jacket Mode) and Speed sensor 38m 58s
    • All activities with GPS set to All + Multi-Band
    • General use: AOD disabled with 15s timeout and brightness 2/3, gesture and touch enabled
    • During activity: AOD enabled with 15s timeout and brightness 2/3, gesture enabled, touch disabled
    • Sleep mode: 22:00-06:00, watch face sleep, touch off, DND on, battery saver off, display timeout 8s brightness 1/3
    • Pulse Ox off OHR on
    • Stock watchface
    • No music.
    I come from a 6X Pro with weeks of battery juice and that can also be problematic since you forget about checking battery level and just assume it is ok. My Epix has more than enough for my usage and my activities.
  • Bit early to tell as only on my second week, but am getting about a 1 week with AOD off, wrist gesture on, 8s timeout, 1/3 brightness, Sleep on, Pulse ox off, DND on for sleep, Battery saver on for sleep (but battery saver profile adjusted so HR stays on), GPS tracking using all (more than accurate enough for where I mainly workout not to need dual, so not using it at the moment) for 1hr and then approx another10-30min of other tracking during the day (i.e.  breath work, strength training etc).  When I recharge 1 week later I still have around 38% - so around 9% per day. However that was with heavy usage of the watch - still setting up, trying things, checking stress etc far more than I usually would. So I would expect that to go down.
    So far this week I am 2 days in and was at 84% i.e. 16% 2 days - 8% per day. Still higher than normal usage, but I don't expect it to come down overly much, as I often trigger wrist gesture when it isn't required (I do wish I could turn down the sensitivity). It seems to be around 5-6% per day without tracking (which would give 16 days) and around 3-4% per hour tracking (30-25hrs of continuous tracking - suggesting Garmin's estimates are pretty close - but until you fully run it down you really can't tell).
    Next week will start testing AOD, with wrist gesture off, and suspect will probably see 6-7 days, which means having to charge twice a week (probably Monday and Friday).
  • I'm finding that pulse ox doesn't consume that much power.  I have pulse ox enabled during sleep for 8 hours and the battery only drains by 1-2% points.  The power usage of pulse ox is significantly overstated.
  • I experienced 6.5 days with AOD enabled with gestures for General Use and Smartphone my first week using all satellites and an hour activity each day. Since moved to AOD disabled for General Use with gestures enabled, and AOD enabled for Activities, and gestures enabled. In that mode I show 17 days of smartphone life after a full charge. If I do a 2+ hour activity my smartwatch life drops a day, so still getting 10 days plus some reserve in that mode. Very pleased as that battery life exceeds my 5X quite a bit and can be preserved more using straight GPS if I was paddling on the ocean or road biking. I leave my bluetooth connection off except if I want to sync or have a need and only use the pulse ox occasionally.
  • Interesting as that definitely wasn't the case with F6x Pro where having pluse ox on at night effectively reduced battery life by 1/3.
  • Datum 7XS 7X 5X+ Epix2 Bemerkung
    2022-03-02 09:30 15% - - 100% Vor
    2022-03-02 17:30 15% - - 94% Vor
    2022-03-02 21:00 14% - - 91% Vor
    2022-03-02 22:30 10% - - 84% Nach
    2022-03-03 18:30 9% - - 74% Vor
    2022-03-03 20:30 7% - - 63% Nach
    2022-03-04 06:30 6% - - 62% Vor
    2022-03-04 10:00 5% - - 60% Vor
    2022-03-04 11:00 5% - - 53% Nach
    2022-03-04 16:00 100% - - 49% Vor
    2022-03-04 18:00 98% - - 35% Nach
    2022-03-06 10:00 87% - - 28% Gestern knapp 3 Stunden navigiert mit 7X
    2022-03-06 13:30 85% - - 16% Epix2:links - F7SS:rechts Nach 3 Stunden Spaziergang
    2022-03-06 17:30 84% - - 99% Vor
    2022-03-06 21:00 82% - - 90% Nach
    2022-03-07 06:00 81% - - 87% Vor
    2022-03-07 09:00 80% - - 83% Nach
    2022-03-07 17:30 79% - - 77% Vor
    2022-03-07 21:00 79% - - 74% Vor
    2022-03-07 22:30 78% - - 70% Nach
    2022-03-08 08:00 77% - - 68% Vor
    2022-03-08 09:00 76% - - 65% Nach
    2022-03-08 11:00 76% - - 77% Epix2 aktualisiert auf 7.35, dabei kurz geladen
    2022-03-08 18:00 76% - - 72% Vor
    2022-03-09 07:00 73% - - 64% Vor
    2022-03-09 10:00 73% - - 60% Nach
    2022-03-09 18:30 72% - - 53% Vor
    2022-03-09 21:00 72% - - 52% Vor -> 5km
    2022-03-10 07:00 70% - - 47% Vor
    2022-03-10 10:00 69% - - 40% Nach
    2022-03-10 19:30 67% - - 28% Nach
    2022-03-11 07:00 66% - - 24% Vor
    2022-03-11 09:00 66% - - 100% Vor
    2022-03-11 12:30 64% - - 92% Nach
    2022-03-12 13:00 62% - - 80% ?
    2022-03-13 20:30 60% - - 6% 5-6 Stunden navigiert mit Epix2
    2022-03-13 22:30 60% - - 100% Epix2 geladen, 294mAh, 1h 31min
    2022-03-14 07:30 58% - - 98% Vor
    2022-03-14 09:00 58% - - 95%
    2022-03-14 20:30 57% - - 87% Vor
    2022-03-14 22:00 57% - - 82% 1 Stunde laufen mit Epix2
    2022-03-15 06:30 56% - - 81% Vor
    2022-03-15 09:00 56% - - 78% 30 Minuten laufen mit Epix2
    2022-03-15 18:00 55% - - 71% Vor
    2022-03-15 20:30 54% - - 65% 1 Stunde laufen mit Epix2
    2022-03-16 07:00 54% - - 61% Vor
    2022-03-16 08:00 54% - - 58% 30 Minuten laufen mit Epix2
    2022-03-16 20:00 52% - - 50% Vor
    2022-03-17 00:00 52% - - 44% 1 Stunde laufen mit Epix2
    2022-03-17 07:30 51% - - 42% Vor
    2022-03-17 09:00 51% - - 38% 30 Minuten laufen mit Epix2
    2022-03-17 20:00 50% - - 30% Vor
    2022-03-17 23:00 50% - - 22% 1 Stunde laufen mit Epix2
    2022-03-18 06:30 49% - - 20% Vor
    2022-03-18 18:30 48% - - ? 30 Minuten laufen mit Epix2
    2022-03-18 12:30 48% - - 100% Epix2 geladen, 269mAh, 1h 28min
    2022-03-21 07:30 40% - - 54% 3 Stunden 7FSS, 1 Stunde navigiert mit Epix2, 30 Minuten laufen mit Epix2
    2022-03-21 08:30 40% - - 51% 30 Minuten laufen mit Epix2
    2022-03-21 23:00 39% - - 37% 1 Stunde laufen mit Epix2
    2022-03-22 07:00 38% - - 35% Vor
    2022-03-22 08:30 38% - - 32% 30 Minuten laufen mit Epix2
    2022-03-22 18:00 37% - - 23% Vor
    2022-03-22 22:30 37% - - 17% Knapp 1 Stunde laufen mit Epix2
    2022-03-23 08:00 37% - - 13% Vor
    2022-03-23 17:30 36% - - 100% Epix2 geladen, 271mAh, 1h 30min
    Epix2 needs charging every 3 or 4 days...
  • For me over 6 days. I use always on display and I’m doing 7 workouts a week, but only 3 workouts use GPS for 45-60 minutes each (still in winter mode Slight smile) the rest are indoor workouts so no GPS. screen is off at night and I don’t record pulse Ox during sleep. I run night mode on the watch from 9:30 pm- 5am.
  • My only issue is when I run with music.  GPS default all systems, no sensors but playing music, Display AOD but its in its dim setting most of the time unless I turn my wrist to look., I use up around 18% per hour.  Thats about 5.5 hours of GPS + Music which is less than the advertised 9 hours with AOD.  That is my issue, I go for a two hour run and I am down 40%. Can anyone else chime in on GPS All Systems, AOD and Music?  Btw I stream via Spotify.
