ETA on Offline calendar support ? (more often it shows nothing then it works, even when connected to iphone)
What is the eta to make calendar supporting offline mode ?
Calendars are not that big and often are from < 1KB => 200KB the biggest ones...
Currently my epix (with newest firmware), constantly showing nothing on my calendar, despite having always meetings either this day, or a next day.
My Apple Watch works fine in offline and when I am cycling I was able quickly check when is my next meeting to know when I should be coming back (I am working in multi-time-zone environment and I cannot possible remember times as each meeting can happen with a person in different timezone).
When will you add this feature to Epix 2 ? It is a huge deal-breaker to me that I still have to wear Apple Watch on my other wrist.
Epix 2 sapphire (Today's fw), Iphone Pro Max 12 (newest fw).
  • I'm having the same problem and it's really starting to tick me off.
  • Mine DOESNT work like this Shrug
    I have the calendar widget - and I can see tonights entry for the mighty Huddersfield Town's fixture at Millwall.
    If I airplane my phone, the glanceable widget still shows the fixture, but there is now a red ! to the left.
    Clicking to expand into the calendar, a warning appears saying something like, "connect the phone to refresh the calendar"...backing out of that, but then clicking to expand into the calendar again, tonights football and future events are visible just as always.
    I reconnect the phone and the red ! disappears.
    Are you sure you're not seeing that simple Warning and thinking it means, "the calendar isn't available at all" ??
  • Calendaring is a many-tentacled issue, with many various calendar sources and formats needing support. In MY case, for instance, my calendaring works great, to my Google Calendar (that's what we use at work, and it syncs fine, all good, no issues). I also just created a test event in the default iOS native calendar on my phone, did a sync, and that event shows fine on my Epix.
    In your case, what calendar type that you're using isn't working?
