After 7.24 update, no Stryd data on Epix 2
I was getting Stryd data successfully up until the 7.24 update.  After 7.24, no Stryd data.  The watch shows "fp connected" when I start a run, but when I look at Garmin Connect afterwards, it doesn't show the Stryd Data fields.  The Stryd pod is charged, and I am able to get for these runs from it with the Android app.  So the Stryd is recording data.  When I look at sensors on the watch, it shows the Stryd, and shows "connected".  Stryd power field is still there.  Anyone else experience this?  Suggestions for fixing it?  Thanks.
  • It’s the ConnectIQ field StrydZones that stores that data into the activity, not the sensor settings…so maybe start with checking the field setting in ConnectIQ, it needs your Stryd username.
    ie..You don’t need the FP connection unless you want to use the Stryd for pace instead of GPS…try it, you can disable all sensors and StrydZones will still work.
    FP connection gets you the pace and distance from the Stryd if desired, and a PWR connection is required if you want to display power in a field such as RunPowerWorkout (although if you use this, you still need the StrydZones field to get the power and other running dynamic fields into the activity).
  • That fixed it, thanks.  Everything was fine except my username was no longer in the StrydZones settings.  Everything else was correct.  Re-entered my user name and gave it a quick test - it's recording again.
    Last run before 7.24 all was fine.  Every run since then had no Stryd data, so somehow my username disappeared the same time the FW updated.
  • Every run since then had no Stryd data, so somehow my username disappeared the same time the FW updated.
    Exactly same thing happened to me. Not sure if it was firmware related or sync of settings from the IQ App to the watch.
