Connect don’t show sleeping if I use my non primary device (Descent MK2i).
my primary device (Epix Gen2 ) if turned off.
Do you have Physio TrueUp turned ON for both devices?
For Garmin Connect Mobile running in iOS, this setting can be found in Garmin Devices > System > Toggle Physio TrueUp On.
After syncing both devices, any sleep data recorded on either device should show up on both - and in Garmin Connect.
HTH
I just find this in the help system:
“It will also allow your watch to track your sleep metrics as only the Preferred Activity Tracker can provide that data.“
so this is kind to ask if there is possible add the ability to sync sleep recordings from multiple devices.
As far as I know, a device must be set as the Preferred Activity Tracker to record sleep data. Only one device can be set as the Preferred Activity Tracker at one time.
So, if you want to keep data within the Garmin system, no, it is not possible to record and sync sleep data from multiple devices at the same time.
HTH
