I recently purchased the Enduro 3 and I’m very happy with it so far — but I’m having an issue with the backlight not working.
Here’s what I’ve tried:
Adjusted all backlight settings (brightness is set to 100%)
Ensured battery saver mode, DND and focus mode are turned off
Enabled both “Gesture” and “Button” activation under the backlight settings
Updated the watch to the latest software version (15.32)
- Hard reset
When I press the top left button, nothing happens — the screen doesn’t light up. However, if I hold the button, the control circle appears, and if I double-tap, the flashlight activates. So the button itself seems to be working properly.
Is there something I’m missing, or could this be a hardware issue with the backlight?
Thank you in advance for your help.
