Sunrise & Sunset 1 hour off
Hello everyone,
I just noticed that the sunrise and sunset times are off by exactly one hour.
I am located in Europe, could this be a bug where they’ve already accounted for daylight saving time? (For example, daylight saving time is already in effect in the US but not yet in Europe.)
Regards
  • I'd suggest trying 3 things......
    1. Restart the watch by holding the top left button in continuously until it switches off, then push it again to restart.
    2. If that doesn't fix it, go outside and start a GPS-based activity to make sure your watch has you at the right location.
    3. If that also fails to fix it, do a time sync using GPS as follows:
    From the watchface push and hold the middle left button to bring up the menu then goto
    Watch Settings > System > Time > Time Sync & press the top right button.... When it brings up the next screen make sure Use GPS is shown at the bottom (you can toggle GPS / Phone with the bottom left key).
    After it syncs you should (hopefully) see the correct time in your sunrise & sunset, you may need to restart one more time
  • I only tried 2 & 3 so far. But 1) has fixed it.
    Thanks!
  • It's surprising what that restart procedure can fix Grin
    Glad I could help Thumbsup
