Battery life issue GPS - Enduro 3
Hi all,
First time posting on this forum. Hopefully somebody can help!
I have been using the Enduro 3 for about 5-6 weeks now and the battery life in GPS mode seems to be off.
At the moment I have been going on short runs, typically 30-45 minutes. Each time I do one of these activities the battery typically loses 2 percentage of battery (occasionally 1). Yesterday I ran 36 minutes and I lost 2 percent of battery and the expected hours you can do a GPS activity for went down from 43 to 41. I use normal power mode and for sattelite setting is set to 'auto select'. I am not exactly sure how long the battery is supposed to last in these conditions, but these numbers do not add up I think. If it uses 2 percent of battery for half an hour run then it would last like 25 hours on full battery and if it uses 1 percent it would last like 50. (don't know if you can calculate it this way but it was the best way for me to approach it). Even in all systems + multiband mode it should last about 60 hours.
I have no additonal apps or widgets installed and I would classify my use during the run as typical. I do not use the maps screen during the run. Also my smartwatch mode battery life seems to be okayish. I think. it lasted about 3 weeks on the first charge and is on track for 4 weeks for the second. I typically record 3-5 activities per week.
To me the battery life in GPS activities seems quite a bit off hopefully somebody can shed some light on this!
  • Hello,
    I am sorry to hear you are having trouble with battery drain. Our engineers are still investigating battery drain concerns associated with the Enduro 3. They would like to point out many things that are expected to increase battery drain beyond the estimated days remaining. This could include any of the following:
    • GPS (in particular All satellites, or Multiband settings will use more battery life)
    • Backlight (It is recommended to reduce the brightness. Gestures will turn this on more frequently)
    • Notifications
    • Alerts
    • Vibrations
    • Animations (as with yoga or breathing activities for example)
    • Connect IQ apps or watch faces (many of these have been found to drain the battery more quickly)
    • Pulse OX either All day or During Sleep
    • Paired sensors
    • Music
    • Paired Bluetooth headset
    • Watch faces with second hands
    So when you are measuring your battery drain, be sure to take these items into account. If the battery drain still seems excessive, or you are even seeing rapid drain when the watch is in battery saver mode, please feel free to reach out to me via Private Message.
  • hi. i can suggest you at first, that do HARD RESET on your watch. i hope it works as mine, and be careful that your backlight time is not on long time. when your cell phone and watch bluetooth is always on, it will drains more power because it'll search your cell phone permanently. turn off your watch WIFI, when it's not necessary to use that for sync or update.
  • Can you see how much lux do you accumulated?
    Yesterday I did almost 5 hours trail run on all systems gps, the battery drop with 8%. I was with third party hr armband. With 108k lux accumulated. With my calculations tge battery will last for 80 hours this is the manufacturer prediction but without the solar...
  • I agree, the battery drains way more than what was marketed for. It lasts around 3 weeks max with around 3 hours activity per week. In addition, the batyery performance is almost the same if I leave it on my desk without any use! My Epix Pro 51mm or even my older Fenix 7x are better specially when I leave them on my desk without using them.
  • Hi,
    This is an interesting post. I ran a 100 mile race at the weekend in UK winter conditions which took me 27 hours. Very little sunlight so virtually no solar. WIFI switched off and phone connection switched off in GPS only 'ultra' mode. Course loaded but only referred to a few times as course was well marked and immediately moved off map screen.
    I had 57% battery left immediately after the race so that would give me about 63 hours total in ultra mode.
    I've installed the battery app to see what is draining the power but did notice that the auto 'rest' timer was on and would not stop even though I was moving faster than the default speed to stop it. Really dissappointed actually as it does seem to work well for some. I am on the latest software version.
    Billy
