Hi all,
First time posting on this forum. Hopefully somebody can help!
I have been using the Enduro 3 for about 5-6 weeks now and the battery life in GPS mode seems to be off.
At the moment I have been going on short runs, typically 30-45 minutes. Each time I do one of these activities the battery typically loses 2 percentage of battery (occasionally 1). Yesterday I ran 36 minutes and I lost 2 percent of battery and the expected hours you can do a GPS activity for went down from 43 to 41. I use normal power mode and for sattelite setting is set to 'auto select'. I am not exactly sure how long the battery is supposed to last in these conditions, but these numbers do not add up I think. If it uses 2 percent of battery for half an hour run then it would last like 25 hours on full battery and if it uses 1 percent it would last like 50. (don't know if you can calculate it this way but it was the best way for me to approach it). Even in all systems + multiband mode it should last about 60 hours.
I have no additonal apps or widgets installed and I would classify my use during the run as typical. I do not use the maps screen during the run. Also my smartwatch mode battery life seems to be okayish. I think. it lasted about 3 weeks on the first charge and is on track for 4 weeks for the second. I typically record 3-5 activities per week.
To me the battery life in GPS activities seems quite a bit off hopefully somebody can shed some light on this!
