Not in the list of supported formats, FLAC is a standard audio format and far more common than apple lossless audio:
https://support.garmin.com/en-US/?faq=JyNEOTsZaR3KMXqej3oQp5
Please make this a priority and support in the next release.
Do want them to update the BT Codec to support the quality too?
Hi,
Maybe in your case this could simplify your music file management without file conversion only for Garmin device ?
Fenix 7X, Silicon Labs RS9116-B00. It has Bluetooth capabilities with dual mode Bluetooth 5 support. It supports Bluetooth 2.1 + EDR, Bluetooth Low Energy 4.0 / 4.1 / 4.2 / 5.0
I was not able to find which version is supported on F8 or which chip is used.
Regarding Connect IQ Music App, i was not able to find format/bitrate etc. infos ...
https://www.whathifi.com/advice/bluetooth-5-everything-you-need-to-know
https://www.soundguys.com/understanding-bluetooth-codecs-15352/
| Bluetooth Audio Codec | Maximum Bitrate | Bit Depth | Maximum Sample Rate |
SBC
320kbps
16-bit
48kHz
aptX
352kbps
16-bit
48kHz
aptX HD
576kbps
24-bit
48kHz
aptX Adaptive
279kbps-420kbps
24-bit
96kHz
aptX Lossless
1200kbps
24-bit
96kHz
AAC
264kbps
16-bit
44.1kHz
LDAC
990kbps
24-bit
96kHz
LHDC
900kbps
24-bit
96kHz
Samsung Scalable Codec
88kbps-512kbps
24-bit
44.1kHz
LC3 (BT 5.3)
345kbps
32-bit
48kHz
As you can see, it’s easy to get lost in Bluetooth jargon. Remember that higher transfer rates are good, but no matter how great the kbps: you need both your phone and headphones to speak the same language.
But the truth of the matter is that codecs are starting to matter less and less as development improves. Unless you absolutely must have the highest bitrates or a feature of a particular codec, the standard SBC and AAC will be able to meet the needs of the vast majority of people.
As FLAC is uncompressed PCM it doesn't need a codec per se vs. compressed formats like MP3, AAC.
There is no decoding involved (the DEC in codec)
But Bluetooth Silicon Labs RS9116 only support SBC A2DP, so compression is done when streaming from your watch to external speaker.
I'm agree with your regarding the fact that source could be lossless or uncompressed, then the result should be better than using MP3 high bitrate and compress using SBC.
I don't know if CPU and OS is capable to read/handle FLAC, NXP MRT595SFFOC
It does not matter if you have Flac if you have to listen to it using SBC, SBC sounds like crap. And the watch probably does not have the computing power to do any better. Though it seems APTX uses less resources while sounding better.
