Does anyone use custom maps in KMZ format?
With the latest update, you can now select non-Garmin maps (third-party maps) but you cannot select custom maps in KMZ format or not. They can be seen in the map viewer, but they cannot be activated or deactivated, so they are always active and the only way to deactivate them is to delete them from the device.
Has anyone found a way to activate or deactivate this type of maps? On every other
Garmin watch I've owned, including the Enduro 2, it could be done without problems.
Thank you and greetings.
