Suddenly, five days ago, intensity minutes stopped logging/recording.
Anyone else notice this?
It's absolutely messing with everything else.
Mine is recording intensity minutes as usual. It recorded 56 minutes of moderate yesterday while I tracked a walk activity
v11.89 software
I have suddenly also got this same issue. Specifically with the mountain biking activity. Did you find a solution to fix this?
10 kilometers per day... every day.
The distance is unimportant. What plays the major role is the number of minutes your HR is above ~150% of the 7 days average Resting HR (unless you…
Are you sure you actually had any intensity minutes during the past 5 days? Did you try doing a workout today and see if it logs?
Yes. 10 kilometers per day... every day.
I wouldn't have posted the question otherwise.
The distance is unimportant. What plays the major role is the number of minutes your HR is above ~150% of the 7 days average Resting HR (unless you configured the IMs to use HR zones instead). Post the screenshot of the all-day HR, the 7 days avg RHR value, and the IM graph for given day, and let us look whether there is something wrong or not.
Did you start/stop/save your workout as an "Activity"?
It's the same for me too. I'm sending it for assistance
yes
I'm not wasting my time with all that. Been using Garmin watches for years. Suddenly, intensity minutes stopped recording five days ago. While my daily workouts vary every day... I hit my thresholds. Yes... it varies every day. Suddenly, flatline and nothing.
Saving an activity is unimportant too. It is the ratio between HR and RHR that decides whether any Intensity Minutes are awarded or not. Without you posting the requested data, it is impossible to tell whether you should have get any or not.
You can read more about the feature of Intensity Minutes in the document How Does the Intensity Minutes Feature Work? | Garmin Customer Support
Well, if you do not need any help from fellow users, then do not waste your time on the user forum, and contact directly the Support at https://support.garmin.com.
I know how it works, and I know how to read the manual. I posted the question, because it suddenly stopped working, as it should be working... per the manual.
My question was not for help. My question asked if anyone else was having an issue. One person seems to have understood that question.
This pattern repeats itself every week for years. Last week, with me doing NOTHING different than I have done for years... it flatlines. And, yes... I ran every day.
