Problems with BT headphones when using HRM Pro+ at the same time
Is anyone else experiencing the same issues with BT headphones when using them simultaneously with HRM?
When I try to play music using the watch and only the headphones everything works ok, when I click “play” the watch immediately finds the headphones and plays music (on the watch screen or during a workout).
When I connect HRMpro+ the problems start. The watch can't find the headphones for a long time (~20-30s), if it finally finds,it writes connected and doesn't start playing music, I have to press play again, then it usually (not always) starts searching for the headphones again or I hear in my headphones connected disconnected several times (the easiest workaround, when I see that it is connected, I turn on playback on the headphones. It's annoying, when I want to run, I have to fight with the watch to start running ...
btw. i had the same problem on fenix 7x, i think, from 18.14 where it is in the description - "Fixed potential issue with connection of external Bluetooth sensors" (or maybe since one of the updates 17.xx, i don't remember exactly since which one or the problems were in version 17.xx and they got worse in 18)
