Anyone else noticed the battery estimate when using the multi band dual frequency satellite setting is showing far less hours than the spec sheets for the Enduro 2 state?
According the Garmin spec and all the marketing content, this mode should yield up to 68hrs, however the estimate showing on the device when at 100% is only 45hrs.
If you play around with power managed you can get that to a max of 47 but that’s still a long way off 68. Interestingly all other satellite mode estimates match up to the Garmin spec sheet when the watch is at 100%.
Thoughts?
