Hello! Has anyone else had battery problems since the 15.77 update? 1 day: 14% battery consumption.
I also from this update the battery is absolutely not the same 20% in 1 day with Enduro 2 and only 1 h of running but are they joking ???
Did you try the tips from the guide? Certainly not a problem of the update, otherwise everyone would have the problem. More likely just a decalibrated battery gauge. Follow the hints, and you'll be (most likely) all right
I observe also a small battery drain with latest update. Not so huge like previous software problems.
Before this update the battery works very well for this reason I’m thinking the problem is strictly connected with the update, thank u for the tips but I’m not very confident with the watch reset , I have several options and I don’t want to reinsert every option again , sure having an enduro 2 with a battery life comparable with an Apple Watch Ultra is not very funny, at this point I will use my Apple ultra 2….
That's exactly the case the guide refers to, and that what we see reported here on the forums after every single firmware update of any Garmin watch. The suggested fix works in the vaste majority of cases.
After the suggested soft-reset (unlike at the master reset), there is no need to reinsert any settings. Everything stays as it was. It is just a forced reboot of the watch. If you synced the watch before the soft-reset, you lose absolutely no data, and no settings.
Ok I will try thank you very much and have a nice day !
here too Enduro2,,!
I had similar issues with battery drain. After yesterdays full reset and restoring watch from backup battery usage seems to be okay.
I own Enduro 2.
