Anyone run into an Issue where sporadically the flashlight will not activate as normal but will just faintly glow? After turning it off and back on a time or two it shines normally.
If you've had it on for an extended period it could well be the heat protection kicking in.
True but in the times I had it happen, it had been off, no chance that it was hot. Just wondered if anyone else has seen it
This happens once in a while for me. I double press the light button and when it doesn't go full bright, I just cycle it off and back on, then it works. So far it's random and I haven't been able to replicate.
Thanks! I wonder what the cause is?
