Update 22.00 is very crooked and leads to a clock hang when choosing a Russian localization! Tested on 2 different descent mk2 watches!
After the update, the clock freezes at the "Loading FIT Files" stage. If you make a hard reset of the clock and select any language other than Russian, then the clock starts without problems. When changing the language in the settings to Russian, the clock freezes again (only a hard reset of the clock helps)
