Is the Descent Mk2S watch compatible with the charging cables of any other watches?
I lost my cable and it's hard to come by so I'd like to know if any substitutes would fit?
All Descent watches including the Mk1, Mk2 series, and G1 use the same Charging/Data Clip. I don't think anything else will fit. You can order a replacement.
The Mk1 cable is indeed significantly different its Mk2 / G1 counterpart, but the newer cable works with everything in the Descent series. You're quite correct that the original, Mk1 cable is incompatible…
From the pictures on the internet the Mk1 cable looks a lot different to Mk2.
The Mk1 cable is indeed significantly different its Mk2 / G1 counterpart, but the newer cable works with everything in the Descent series. You're quite correct that the original, Mk1 cable is incompatible with the newer devices.
