Does anybody knows what this triangle shows?
My alt timezone is currently 15:11 but the triangle is at 38 minutes?
15:11 is exactly on the 38th minute, on the 24hr outside scale, so it is there where it should be
I have…
Is it working? My alt timezone is currently 15:11 but the triangle is at 38 minutes?
Thank you, Trux. I wish, I was smarter:)
2nd time zone, if you set one...
Thats it...:-)
Thank you very much.
I have the same question. And, my alternative time zone is minus 7 hours. And the triangle seems to be in completly random place. Any other ideas??
Same answer - make sure you noticed the outer 24hr scale. On the standard 12hr inner scale, it could not show the time unambiguously.
Having a 24h display on a display set to 12h?
I guess wrong is more a UI thing than a technical correctness but I am grateful for your explanation.
The display is set for both 12h (inner scale) and 24h (outer scale). As written, on a 12h scale you would not see instantly whether the alternative time indicates AM or PM time.
Definately not the alternate time zone still cannot understand what it shows
Alternative time zone. The ATZ time is shown in small white numbers with 24 at the top position, 0600 in the 3 o'clock position, 1200 in the 6 o'clock position, and 1800 in the 9 o'clock position. ATZ numbers are printed around bezel so not easy to read in low light. But once you understand the logic, lighting isn't so important IMO. You can turn ATZ (triangle) on/off in watch face customization. Cheers
