Here we see the 2 watch
On the right ascent get stuck to 72
Altitude is pretty Right
The instinct work normaly.
If you haven't already done so, please try rebooting your watch. I also recommend ensuring that the sensor port is clean and free of debris, as well as the suggestions outlined in this support article: Troubleshooting the Descent G1 Series Altimeter and Barometer
Please let me know if this issue persists or if you have any questions!
You could check the serial number and compare it with the original you had, but to me it does not really look like a hardware problem - the altimeter (the pressure sensor) clearly works on the right watch, because the absolute altitude varies on both watches. I'd tell that the watch failed to detect you ascent, and perhaps considered that you took a lift. There is clearly no problem with the sensor, so it is not surprising the replacement watch did not help.
I mode trail / hike the "ascent" elevation get stuck
... BTW, using the Hike or Trail for a ski activity is not really a wise choice. These activity profiles expect certain pattern of accelerometer data to help detecting your motion, steps, and cadence. When on ski, the patterns are completely different than what the watch expects. It may then also go into the auto-pause mode, when you move slowly uphill, hence stopping also incrementing the elevation gain (ascent).
Why don't you rather use the corresponding ski activity?
I compare the #serial it's not the same
But the probability to have the same problem on a second watch mean that :
I have no luck
All the watch have the same problem (it common also on Fenix or instinct)
(I detail my answer in your second Post)
First all thanks to your answer
When I say ski. It's mean skin hiking. So I don't take a lift. I climb with ski and skin outside of a ressort. But the problem is the same regardless off what I have to my feet
Got the same problem the day before with my basket on a basic hike
Altitude on the 2 watch are a little different on the pictures but most of the time they are close enough to be right
To finish I don't use auto pause
So : got a new watch, same problem, aways here regardless of activity and present on some.other watch
Thx
Not that :
I have a new watch coming for warranty who have the same problem (so reset factory)
And
I have multiple times make an update (automatic with my phone)
And
Do also a reset factory by following the instructions and using a pc
Problem always happens
And as I told, you can find the problem on Fenix and instinct which means it's more a software problem than a hardware or configuration problem
As I wrote, there is no apparent hardware problem with your watch, since the sensor works. So it is expected that the replacement of the watch cannot change anything. However, if you are really using the Hike activity for crosscountry ski, then it is not surprising the recording is wrong. Use the dedicated Cross-Country Ski activity instead. And disable the Auto-Pause.
Again, do not use Hiking for anything else than hiking. If you play basketball, use the Basketball activity profile.
