Backlight at depth not working
Hello,
I just came from freediving session and realize that backlight at depth not working. I have turned on silent diving in apnea mode and backlight at depth works before, but now it stops. Do you have same issue?
Thank you for your response.
  • I've had a similar issue with the backlight during freediving, and it's a bit frustrating. It used to work when I had the silent diving mode on in apnea, but for some reason, it's not functioning anymore.
    I'm not sure what's causing this problem, but it's good to know I'm not alone. Has anyone else experienced this and found a solution? Your input would be greatly appreciated.
    Thanks for your help!
