Hello!
Incorrect display of the planned route. For example, I create a new route from KJFK to KIAD (Navigation -> Flight Planning -> Saved Plans->Create New and add via Search by Ident). The new flight plan always displays the length - 0.0 nm. When I select Set Active and fly - the watch does not want to follow the route. On the waypoint page, there is no point name, no DTK, no distance... Similarly, if me select Direct To and enter a point, the watch does not fly to the point.But on a map and HSI - all correct. I did a factory reset and a master reset - nothing changed.
I'm not sure, but I think it happened after updating the software to version 27.00.
I also noticed that the Data and ExtData folders are missing from my Garmin folder. I read on the forum that they are supposed to be. When you try to create folders manually, the watch does not allow you to do it. Creates any folder with any name, but not these. Maybe it is somehow related?
Who has the Marq Aviator Gen 1 watch? Is everything working correctly for you? And do you have Data and extData folders in the Garmin folder?
Thank you
