Is anyone else getting a "Database Update Failed" message when trying to update the Aviation Database on the D2 Delta?
A.
A.
Nevermind all, I downloaded the Garmin Aviation database updater off the aviation site and was able to update via the app.
yes me
did it help with the updater
Hi Mike72, as firstinflight wrote yes the updater fixed it. You have the option to update or clear / install the entire database. As I perform a regular full hard reset / software reset on the watch for fun, I just did a full database install. Only took a few seconds and the database now shows an August expiry date.
it worked when connected to comp. tried again now over wifi and got the same error. is it a bug or wifi update is no longer available?
YES
Same problem here with tactix 7 Pro firmware 8.37.
Update of the database via WIFI fails.
Update of the database with the Database Manager on MAC fails (the watch is not recognized by the Database Manager on MAC).
A phone call to aviation support and test of the employee on his MAC confirms my finding.
With the Database Manager on Windows (same version number of the Database Manager) it works fine.
Can someone from Garmin please comment if they are working on this problem ? I have limited access to Windows. Since there is a MAC version of the Database Manager, please can I get a fix for MAC.
... I note that this is still an issue with my D2 Delta (ie - wifi database update fails). Is Garmin Aviation checking these posts?
Probable cause - Target website has moved or certificate expired.....
Resolution - Firmware needs update. D2 Delta has not had an update for over 12 months.
My d2 delta updated to 8.20 yesterday, failure to update still persist
It's 4-5 months since the database update failed error began. It's another thing that there is a way to manually update the DB. However, this is not an inexpensive watch (i understand that expensive is a relative term). It is an aviation watch. AIRAC data download and update is an important feature. The fact that Garmin does not fix it something that was working before is very frustrating. I now have 8.10 and it's still not working.
