Garmin D2 Charlie draining battery too fast after update to v. 6.00
The Garmin D2 Charlie is draining battery faster than normal after updating to v. 6.00. Any one else experiencing this issue? Any fix?
  • Try turning your watch off, then turning it back on again. And then ensure you charge it to 100% and then leave it charging for a bit longer at 100%.
    Are you running a custom watch face or have you recently installed any new widgets that might be using up more battery than normal, perhaps in the background?
    0 Former Member over 4 years ago
    I have noticed today specifically (not sure how long been happening) that my D2 Charlie is draining quickly. Charged overnight last night, went for a short 4 mile run and little walk, down to nearly 90%, by end of the day battery is down to 53%, I'd expect it to at least be in the 80% bracket 24 hours after being charged.
  • I think this might also be happening on the D2 Delta; I too have noticed high battery drain since firmware 6.00. Anyone else with the D2D seeing this?
    0 Former Member over 2 years ago in reply to dbrobert
    hello  Robert there look i am looking for a replacement of the battery of my ad 2 Charlie because just like the collega above when I do run an activity or after charging it 100% at that same day by night says 19% and then I try to like let’s say press the light button and the battery life says 2% when seconds ago said 90% or 80 or even 50% so I was wondering if u can help me Wich kind of battery do I need to find as am living in Spain atm u can either reply me here or to [email protected]m and tell me there please if u knew . Will be much appreciated.
    alex
