Changes made in 7.1:
- added weather imagery
- updates to the weight & balance functionality
- added quick fuel set
- expanded the Summary View
- added warning messages for saved trips
- improvements to SiriusXM support
Hi
My d2 delta is connected to my phone thru the connect app, I have a garmin pilot app subscription. But garmin pilot doesn't connect to my d2 watch? It says that it should connect automatically. What am I missing?
Are you using the Connext functionality to connect? Within the Garmin Pilot app you need to go to the "Connext" tab and then scroll down until you see "D2 Delta.Series" and select that. Once you do you should see the "Connecting" message followed by "Connected" beside the Bluetooth symbol. At that point, your phone/device will use your D2D for it's GPS position and you will be able to transfer your current/active flight plan to the watch.
That's rhe problem, I get a notification to connect via Bluetooth. Doesn't make sense since my watch is already connected thru the connect app as it should?
Removed the watch and added it again and now it seems to be working
Was working for a day, now same problem were it tells me to go to BT settings to connect.
Does Garmin Pilot support KML/KMZ overlays? If yes, is there a guide for uploading and importing them to the display?
Does Garmin Pilot support KML/KMZ overlays? If yes, is there a guide for uploading and importing them to the application map display?
