Changes made from version 4.00 to 4.20:
- Added configuration option (30kt or 10kt) for Flight Timer Auto-record threshold speed when 'Flight Timer' set to 'Auto' (Settings > Activities & Apps > FLY > FLY Settings > Flight Timer Threshold)
- Added support for communication with a Garmin Xero A1i Bow Sight. The Bow Sight is capable of sending Laser Locate waypoints to the watch. These are accessible from the XERO widget (Settings > Widgets > Add Widgets > XERO) and can be further used to navigate to.
- Added Physio TrueUp support. Physio TrueUp syncs activities done on other Garmin devices, allowing your device to more accurately reflect your training status and fitness. Activities from other devices will appear in the Activities menu, and they will update your Totals for Running, Cycling, and Swimming. Your Training Status, Training Load, and VO2 Max will be updated using activities from your other devices, and your Recovery Time will be also updated using data from other devices supporting Physio TrueUp. Enable Physio TrueUp in Settings > Physiological Metrics on the device or in Device Settings on Garmin Connect Mobile.
- Added support for communication with a Garmin inReach Mini. (Settings > Widgets > Add Widgets > inReach) The widget acts as a remote and allows one to send preset texts, customized quick texts and trigger a SOS message.
- Added support for selecting alternate locations within the Sunrise and Sunset widget. (Widget > Menu > Location).
- Added the ability to save Stopwatch recording as an activity. Go to the Stopwatch control, and start the timer. Stop the timer, and select Done. You can then save your activity, which will appear in your History.
- Added the Kayak app.
- Fixed an issue preventing the downloading of Aviation Databases over Wi-Fi.
- Fixed a possible crash on the METAR widget.
- Fixed an issue with the Altimeter widget not using 'Aviation Units' when that option is enabled.
- Fixed an issue with FLY datascreens being configurable in non-FLY activities.
- Fixed an issue that could cause 0 to be displayed in the Grade data field.
- Fixed an issue that could cause the time and date to be incorrect.
- Improved the accuracy of the pace/speed target gauge during workouts.
- Added support for REM sleep phase detection and improved the accuracy of the existing sleep algorithm.
