Hi,
Instinct has a very annoying "feature", apparently if your hike has parts where you stop a lot/go very slowly wandering around.
This will give you significantly worse results on hikes with difficult terrain where you are very slow, stop for seconds, etc.
The following track reads as 22.59 km total distance and 6:02:14 moving time (which is unreal), both in Connect and also on the watch itself.
https://connect.garmin.com/modern/activity/5346322012
However exporting to Garmin Basecamp apparently gives me the correct distance of 24.80 km and 7:01:56 moving time.
That is a diffrerence of ~10% in the distance which is quite poor.
Checking it is Basecamp shows that the data is recorded correctly, but interpreted incorrectly in the watch/Connect app.
Can this be turned off? I have checked every setting but no luck. The watch is set to second by second data recording and autopause is off.
I think this is built in so it would be nice to be able to switch this off as it is giving false results.
Thanks,
Adam
