[Fenix 5 issues] Barometer show "----.-" / Temp. show "---"
I've problem about Barometer and Temp how can i do for them? Since i've wearing them as normal no any damage.
Thank you.
    Hello
    I have the same problem on a Fenix 5x. Have you talked to Garmin? Have you got any solution?
  • Generally not a good sign.  If you haven’t done the basics already try a soft reset, diagnostic mode then full reset.  Support would put you through these steps anyway. Likely one of the sensors is shot (often the temperature sensor as this will also mess up the barometer).
    FYI diagnostic mode;
    Switch off the device.
    Press the down button and hold it
    Press the light button to switch on the device, let it go when the garmin triangle appears
    let the light button go when diagnostic page 1 comes up.
    the lap button will walk through the pages.
