due to problem with EPO, in my case I delete everyday, do you have a widget or app to delete EPO.BIN of our F5X?
We continue to investigate this issue, but do not have a solution. As a temporary workaround, the watch will update distance if you are able to sync with Garmin Connect Mobile, Garmin Express, or plug…
Everyone, we are sorry for the delay but I'm happy to report that in the current 14.73 beta software has a fix for the Zero Distance Issue.
Feel free to install the beta software and report in the…
I now have a 5x Plus so I no longer have this issue. However, syncing my 5x with Garmin Connect mobile did not work, nor did plugging it into a power source. The only workaround that did work was plugging…
This seems to confirm previous reports we've had on this and other threads:
1. Fenix 5x Plus used to have this bug during beta phase, but it was fixed before release version. Somehow the fix isn't…
i updated -> restarted the watch -> went into maps -> have chosen a point on the map -> navigated to it -> IT WORKED!!! :-)
restarted again -> went into running -> navigate to a saved location -> IT WORKED!!! :-)
restarted again -> went into navigation -> have chosen a POI -> startet it -> and IT WORKED again!
Thanks very much!!!!!!!!! Garmin-Heath :-)
Indeed looks like it finally works again!
Thanks a lot! How many beers do you want sent your way?
I did not remove my watch from my mac pro properly
I just ejected my fenix 5x properly from my mac pro and the navigation works presently
I will see if it works when I turn my watch off later
if 14.73 fixed this problem, then why did I have the same problem 4 months ago and also today with version 20.00? https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-5-series/217335/software-problems-fenix-5x
Hello Garmin-Heath,
I use a Fenix 7 Sapphire Solar since May last year, now running on firmware 13.22, and I am still (June 2023) having the same issue! This is really so disappointing.
I mainly use it for sailing navigation and sail racing ("racing" app) and create the course with the explorer app or the watch itself. However I created the courses (in German "Strecke") - distance to next waypoint is zero and also time to waypoint not working.
What is up with you?
Regards
Michael
